torque ???
Old Feb 19, 2012 | 08:39 PM
bigantws6's Avatar
Default torque ???
When torquing the main caps and rob bolts do I need to torque with degree quell
Old Feb 19, 2012 | 10:07 PM
gMAG's Avatar
When torqueing the rod bolts and main caps, there is a torque value, then a subsequent degree value.
In this order...
Mains...Inner bolts 15lbs
...Outer bolts 15lbs
...sides bolts 18lbs
Then...Inners 80 degrees
...Outers 53 degrees
Rods...15lbs + 75 degrees
Old Feb 19, 2012 | 11:48 PM
bigantws6's Avatar
Cool bro thanks for the info just wanted to make sure
