Can I use this cam on a stock engine?
Old Mar 21, 2004 | 06:04 PM
snketr's Avatar
Default Can I use this cam on a stock engine?
I have an LPE custom cam that I got off ebay. The sheet says 222/350 222/350 112.5 I was told it was .595 lift, so that would mean it is with 1.7 rockers right? Can i put it in my 140k engine without flycutting the pistons?
Old Mar 21, 2004 | 06:06 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
.Yes.
Old Mar 21, 2004 | 06:13 PM
99SilverC5Coupe's Avatar
Originally Posted by SouthFL.02.SS
.Yes.
You will need a valve spring upgrade with that lift..but I agree that PV clearance should be ok...
Old Mar 21, 2004 | 06:14 PM
jrp's Avatar
jrp
SN95 Director
yes you can. i'd do a compression and leak down test to make sure you engine is still sound before doing any internal work.
