Cam split pattern logic and results?
Old Apr 1, 2004 | 08:42 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Originally Posted by myZ
LoL
then i'll get my powerband where i want it 3000-6000 rpm
Actually, what is funny is that they idle better than most of the H/C cars I see here in the states. I talked with a tuner in Australia yesterday. 242/242 on a 106 idling at 800 rpm. They also are working on a 263/263 that in a 3800lbs Holden that idles below 900 and went a 11.0 @ 128 on pump gas. I'll have more results later this week, but they are definitely making some power, and the cars are very drivable. As I have driven them while I was down there....
Old Apr 7, 2004 | 07:56 AM
Plan B's Avatar
That would be Chris's car. It made 638 fwhp at 6,800 rpm. Just a garden variety Lunati 383 stroker with Higgin's LS6 heads and Sam's tuned 8tb's.
Indeed, it does drive nicer than an un-tuned stock engine with a 216-220 on 114lsa…. Yep!
Old Apr 7, 2004 | 08:23 AM
gator's 99TA's Avatar
Plan B J-rod or anyone, please lets get some of these cam and programing combos in the states! i am SURE there is a market for this!
Old Apr 7, 2004 | 09:37 AM
Plan B's Avatar
Aussie’s frown upon $50 mail order tunes…. It’s easy with a stocker but you’ll have to be on location with the larger cams.
Find a tuner over there, who knows Mr. Eddy Current, and you’ll go a long way to making this stuff more livable.
Old Apr 7, 2004 | 10:39 AM
J-Rod's Avatar
I'm working on locating Mr. Eddy Current now...
Old Apr 7, 2004 | 10:54 AM
Cstraub's Avatar
Just got done with SBC cam for a good customer, car will be one of these street race NMCA or something, 417CID with a set of All Pros. To relate to calculating duration split. Customer supplied the numbers on this head but due to the fact he is getting a cam from Al Parker also, I wanted him to flow the induction system in tact for real numbers. This cam had to my best work. ..Parker is an Ace on NA stuff. Cam would have been a 2 degree split, but due to the Intake package and the exhaust package flow numbers cam is now a 6 degree split. Power would have suffered.
Relating to the LS1's, since the intake is so restrictive, it is a good idea for those of you wanting to put something on KILL, to have the shop bolt everything on the heads and flow them that way.
J-rod, find a Dave Jax (Jacks) over in Aussy land, I have just seen some of his work on cylinder heads, NICE work.
Chris
