oil pressure gauge
Old Mar 21, 2004 | 11:26 PM
Myth01's Avatar
Default oil pressure gauge
having an issue with my oil pressure gauge. at idle its seems to flutter, it never gets below 40p but the flutter has got me concerned. the driveability in unaffected. see my sig for my mods. also this is a new occurence
Old Mar 22, 2004 | 12:31 AM
Cal's Avatar
Cal
Sounds like a measurement problem, I doubt the gauge can respond to actual presure fluctuations fast enough to cause the needle to flutter. It could be the gauge itself is bad or the wiring conected to it isn't making a good connection.
Old Mar 22, 2004 | 12:43 AM
Jason99T/A's Avatar
I can shift faster than you.
I agree with the above. Check your oil level and add as needed. If the level looks good, possibly look into a faulty sending unit.
Old Mar 22, 2004 | 07:45 AM
TaTommyWS6's Avatar
Is it flutterring at idle? After I installed my cam, and my idle is lopey, it flutters a bit at idle, but it is totally RPM related....
Tommy
