Max Cam lift for a daily driver?
My current daily driver is an L33...stock compression, but with ported/flow benched heads w/918 springs and shortie headers with dual 2.5 exhaust w crossover. I just bought a Fast LSXR intake, and have a spare 90mm tb that I'm going to be installing as well.
Due to lifter issues, I'm going to be pulling the heads off and replacing the lifters soon....so I thought it would be a good time to replace the z06 camshaft with something different.
My concern is maximum lift vs/ reliability. I've read in some threads where people state that they only run a set of valve springs for roughly 20k miles...but these are guys that are running in excess of .600 lift.
My car sees roughly 30k miles/year...so swapping springs once/year is just not an option for me.
I'm wondering what would be the most amount of recommended lift and ramp rate for a daily driver....something that would last 50-70k miles without having to replace the springs.
Any thoughts/comments/suggestions are welcome.
Quite honestly, it's probably the lobe profile that's really going to shorten the life of springs. Maybe I've dranken the purple koolaid, but it does seem that the EPS lobes are purposefully designed to be easier on the valvetrain. I would call him up and tell him your goals.
I've heard that as well. Probably time to make a phone call.
BTW....kick *** Rx7! I just might have to take a road trip to check it out one of these days!
After speaking with Geoff @ EPS, I decided to order. We're changing out to dual springs and going with a lift right at .600. He ran a profile similar to this in one of his personal vehicles for 45k without changing springs, so it sounds like reliability is decent....plus, I'll have the added insurance of dual springs if something decides to go bad.
As well how you drive the vehicle makes a difference on springs. If your running up to 7k before shifting it on a regular basis those springs are really getting worked, and out of control valvtrain wears it out quickly. Another factor is what spring you are using, I'm not sure I would want to use a 918 for a moderatly aggressive stick, when wanting to maximize mileage. I don't want to get into a debate about which spring is the best, but I'm sure that if you do some research you will see some manufacturers and models are perfered over others. Personally, I would not run Chinese valve springs, and some of the major manufacturers have outsourced thier entry level springs to China.
To be honest for high mileage, you Z06 cam is not a bad choice, but does leave a little on the table.
My new lifters shipped out today and I just picked up an LSXR 102 intake....but it'll be 3 weeks until the cam and new springs/retainers get here.
The only "plus" right now, is that the weather here is crap...so I don't feel like working in the shop right now.....but it'll all be over soon enough, I suppose.
