which set of heads??
http://www.ebay.com/itm/AFR-205cc-64...item563062aa67
I have an 02 LS1 with the following mods:
Set of Pace setter headers
Hooker cat back exhaust with off road pipe
custom grind cam
converter
crank pulley
port and polished throttle body
373 gears
adjustable koni shocks
front strutt tower brace
high flow fuel pump
high flow oil pump
sub frame connectors (weld in)
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
