Losing oil pressure
Old Mar 6, 2012 | 05:43 PM
hifi dream's Avatar
Default Losing oil pressure
After the head/cam install on my 04 GTO I'm now having a problem with oil pressure.
Car runs great for about 10 minutes until it gets warmed up.
Once warmed up the engine starts making more noise and if you come to a stop the oil pressure on the JHP gauge goes to zero and the "check oil" message comes up. Obviously turning if off quick just in case.
Let it sit for awhile. Start it up and it's fine. Engine sounds great and the oil pressure is up. Drive around for a bit, same deal.
Part of the cam install was a new TSP oil pump.
I had the engine out of the car when I put the pump on so I know the o-ring is lined up fine.
Thoughts?
Thanks
Old Mar 6, 2012 | 10:29 PM
NemeSS's Avatar
Dam
that would make me nervous. Ive never heard of this symptom. Worst i seen. a guy brought me in a dwindling oil psi car. I pulled off the stock pump, installed one i ported and shimmed. Ran like a champ for another 2 years. It got worse for him when the oil was wearing down. Came in as low as 20psi or just under.
0 pressure means failure. Usually. ive heard of debris in the pickup screen can also cause low pressure. Sludge or other byproducts.
May want to pull the motor and do a big WTF check
Old Mar 7, 2012 | 11:25 AM
gMAG's Avatar
Yeah, I've just gone through a similar thing as the poster above.
Do you have any shiny metal in the oil?
If so, I might recommend at least removing the oilpan to see if any of the rod caps can be moved.
Since you changed the cam, is it possible that the bowtie seal on the front of the cam is compromised?
Old Mar 7, 2012 | 05:28 PM
Doug G's Avatar
The motor I bought had a 0 oil pressure...they changed the OP and still 0 even with a mechanical guage. Motor got changed and I bought the core knowing it needed a rebuild.
Long story short....wiped cam bearing (#3)....thought it spun, but after taking to machine shop and having them measure...it was just wiped.
I hope that's not the case for you.
Old Mar 8, 2012 | 12:26 PM
hifi dream's Avatar
I was planning on changing the oil tonight, so I'll see what I find there.
