what am I doing wrong?
Old Mar 11, 2012 | 09:03 PM
98workhorse's Avatar
Angry what am I doing wrong?
I have a fresh 383 ls1 with 15 mile on it. When I first started it up I only had 20 psi of oil pressure. No problem, replaced the pump with a ported slp one and a stiffer spring. Everything was good for 15 miles! 15 miles then i noticed it dropping again so I changed the oil sending unit and nothing. Is it the pump again or should I what ? Any help is greatly appreciated.
Old Mar 11, 2012 | 09:10 PM
SOMbitch's Avatar
Is the barbell plug in the back of the block. New OP o-ring and are you sure it is not pinched??
Old Mar 12, 2012 | 04:47 PM
rabbitsws6's Avatar
Mine was doing same thing. Ito was my sending unit
Old Mar 12, 2012 | 04:54 PM
thunderstruck507's Avatar
Did you check it with a mechanical gauge?
Old Mar 12, 2012 | 06:22 PM
mpatton's Avatar
Oring may be pinched.
Old Mar 12, 2012 | 06:51 PM
gMAG's Avatar
This comes first.
If a mechanical gauge mimics the electronic gauge, you have a problem.
Was the 'fresh' engine working well before?
Old Mar 13, 2012 | 02:12 PM
Originally Posted by gMAG
This comes first.
I am going to check it with a mechanical gauge. I changed the sending unit with the same results. The motor was fine before all this started. even to pull it in the garage it was running fine.
Old Mar 13, 2012 | 02:14 PM
I might be a noob for asking this, but what barbell on the back of the block?
Old Mar 13, 2012 | 02:48 PM
Tainted's Avatar
its an oil galley plug near the flywheel area and if its not in the block, or the oring is bad, little to no oil pressure. and a royal PITA to get to (ie drop the tranny and all that =/ )
Old Mar 15, 2012 | 04:43 PM
ok so I installed a mech gauge last night and the oil pressure reading was at 20 psi at 2000 rpm. so Im stuck. should I tear the front apart to check the oil pump o-ring or dig into the back of the block for the barbell plug?
Old Mar 15, 2012 | 05:39 PM
RezinTexas's Avatar
if you had good oil pressure for the first 15 miles, the barbell is not your problem.
Old Mar 15, 2012 | 07:18 PM
S10xGN's Avatar
I'd start by cutting open the oil filter...
Old Mar 16, 2012 | 09:22 AM
What will cutting the oil filter accomplish? I'm not being funny I really want to know.
Old Mar 16, 2012 | 09:38 AM
Deviant LS1's Avatar
You'll open it up and find out if you have bearing material or metal shaving ect. inside of it.
Old Mar 16, 2012 | 09:59 AM
J-Train's Avatar
I'd put money on a pinched o ring. Seems to be fairly common to cam swapers when they do the oil pump. One of the reasons I just left mine alone.
Old Mar 16, 2012 | 08:31 PM
S10xGN's Avatar
I'm thinking if he got 15 miles out of the 2nd pump and then had problems, it wasn't the 0-ring, but bearing material in the system due to either the low oil pressure from the 1st pump or "other" problems...
Old Mar 18, 2012 | 06:45 PM
So basically change oil pump again, or...
Old Mar 18, 2012 | 07:02 PM
hcb1700's Avatar
Nope, he's saying that you bearings could have gottend damaged with he low oil psi with the first pump.
hcb1700's Avatar
Did you cut the oil filter open?
Old Mar 20, 2012 | 02:12 PM
I had to work all weekend and I have school tonight but when i get home Im going to try and cut the filter open to determine what my next move is going to be
