High lift and the effect of injector duty cycle
The answer was the same...that the injector function was based solely on air/fuel/temp.
If you do get bigger injectors, then you need to go in and change the flow rate table....a quick dirty way to do this is say your stock injectors are 28lb hour, and you are going up to a 42 lb hour injector you can highlight the whole table and divide it by 28, then multiply it by 42 to get real close.
