Darton Sleeved 427 LS1 build
Okay here is what i have so far and I know these parts are not ideal but they are what I have and I am needing advice on this build.
I have the block, TSP terminator 203 CC (super small head I know this but it is what i have), new 228R cam (smalllll for a 427). I was planning on ordering a kit from Texas speed for the 4.125 bore that comes with a forged rotating assembly for around 2000 dollars. I do not want my car sitting around for any longer than it has to with summer coming up so I am trying to do this build for around 4 grand using the parts I already have. I figure I can swap the heads n cam later if need be.
I came across a deal on some pistons for a 388 using a 4.125 bore and stock stroke with a 6.1 rod. Would this be better for me to do since I am using such small heads and cam? Or should I big cube it now and worry about the topend later?
The car is a 01 M6 C5 with 1 3/4 longtubes, vararam, ls6 intake, full exhaust, 38 lb injectors. I have HP tuners with the custom operating system that can tune on the fly. TNT wet kit also.
I am not finding much for a 4.1 inch bore piston wise so I feel having it bored to a 4.125 is my best option. Any inputs and suggestions?
My goal is a very dependable driver, lots of torque and good street manners. I want it to be a low 11 second all motor car that puts a smile on my face.
Have you considered selling your existing heads/cam/intake combination?? A set of L92 heads, LS3 intake and custom cam would be a far superior build. Used L92's are pretty cheap and LS3 intakes can be scored on E-Bay for around $300 with rails and injectors. These heads could be ported later on should you want more power.
i believe the darton sleaves can handle 4.185?
with that cam and those heads it will be a blast to drive on the street!
i'm guessing 430-440rwhp 475rwtq
I did not have the assembly balanced due to I believe my machine shop can do it cheaper than what TSP wanted for the balancing.( I am having them assemble the shortblock)
I understand the l92 heads and will eventually be what I go with but for now a head change just is not in my budget.
So far into the build I have spent 2750(short block) and have not touched the machine shop bill, gaskets, or ARP main hardware or bearings.
I'm running 12.5:1 static compresson in my 408 with 57cc heads, but a 255/263 .624/.624 115lsa cam so my dynamic compression is back down to 8.22:1 and the motor has a VERY good street manner for the size of the cam due to the extra cubes....you might even went to look at the next size up (around a 255/267)
This year I'm trying to drop 1,000 pounds or more off the car, big rear tires, and swapped out the a4 for a 3speed manual
