Used cams.....
Old Mar 3, 2003 | 11:00 PM
Boo Yeah's Avatar
Default Used cams.....
Is there anything to look out for when buying a used cam?? I am trying to find one and want to know ahead of time what to look for.
Old Mar 4, 2003 | 09:04 AM
Boo Yeah's Avatar
Default Re: Used cams.....
ttt
Old Mar 4, 2003 | 10:03 AM
LQ4somona's Avatar
Don't buy a used cam. It is a major bad thing. The cam specs will be off of what the card says because the cam has been used, and this causes wear on the lobes. The wear has a specific pattern, so unless you got the lifters with the cam, and in to order of where they line up with what lobes I would stay away. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> Sorry to ruin any thoughts of used part glory
Old Mar 4, 2003 | 10:18 AM
thechef's Avatar
Moderator
i disagree the old cams need the matching lifters not so withthe roller cams of today
you are fine buying a used cam for the ls1 and you can use it with you stock roller lifters <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 4, 2003 | 10:20 AM
XtraCajunSS's Avatar
Used roller cams are fine. Just make sure you get a cam card or a Cam Doctor report with the cam before you install it...
Shane
Old Mar 5, 2003 | 03:33 PM
Larry's Avatar
I have installed two used cams in my engine so far without a problem. Just make sure the cam lobes and Journal's are nice and smooth. Check the part number stamped on the cam to be sure you are getting what you think you are.
Old Mar 5, 2003 | 05:29 PM
2001CamaroGuy's Avatar
As has been said, roller cams don't "wear" like flat tappet cams. They a billet steel and the roller causes almost no friction.
Just you caution when buying.....if the cam has 100,000 miles on it....ehhh....might be a good idea to look around for something else....otherwise its all good... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Chris
