clocking piston rings?
Old Mar 23, 2012 | 04:17 PM
ksk1980's Avatar
Default clocking piston rings?
Putting together a bottom end . How are u supposed to set up ring gap location in comparison to the indication mark on the piston above the wrist pin?
Old Mar 23, 2012 | 04:48 PM
2xLS1's Avatar
I don't remember where I got this but it looks ok to use.
Old Mar 23, 2012 | 06:00 PM
davidws6's Avatar
That's the orientation I've used and seems to work good.
Old Mar 23, 2012 | 08:30 PM
ksk1980's Avatar
Ok that matces what ive found thanks guys n im correct by having all writing on the rings facing upwards rite?
Old Mar 24, 2012 | 12:09 AM
bww3588's Avatar
Check with your ring manufacturer. The chamfered edge always goes up. If there is on edge like that usually the dot goes up.
I always install mine 90* from each other. Which this is only for start up as the rings will rotate once it is running.
