Which cam for my stock LS1
Old Mar 29, 2012 | 03:11 PM
93LS1S10's Avatar
Default Which cam for my stock LS1
I have a 02 LS1 that i have swapped into a 93 S10. It is a stock motor with 241 heads. I am looking for a cam that will lope and give some power gain. I know i will have to change valve springs and push rods. I am fairly new to the LS engines. I have heard some cams that i like the sound of but i dont know if they will work with a stock motor. Which cam would be best for my set-up?
Thanks
Old Mar 29, 2012 | 04:14 PM
93LS1Ws6's Avatar
For the best advice, Call TSP Or EPS or see if they chime in. Im going to recommend Any TSP Cam just because i have done business with TSP a few times and have had nothing but good things from them. I think the 224R or the 228R from TSP would be good for your setup! with a lower LSA. 111 or 112
Old Mar 30, 2012 | 11:19 PM
93LS1S10's Avatar
thanks man. ill look into that and see what they recommend.
Old Mar 30, 2012 | 11:31 PM
hammertime's Avatar
As far as your setup goes, we only know you have an ls1/t56 swapped into an S-10.
What exhaust?
What kind of driving? Track, weekend cruiser, DD?
Gears?
Hp goals?
Even the sponsors need this info to start somewhere with you.
