Melling 10296
Old Mar 29, 2012 | 10:01 PM
cajunss's Avatar
Default Melling 10296
I will be doing a head and cam swap and bought a Melling 10296. What spring should I use? Also it came with two orings.
Old Mar 30, 2012 | 02:20 AM
93Z2871805's Avatar
Veteran: Air Force
Is this going in a stock bottom end?
Old Mar 30, 2012 | 06:00 AM
cajunss's Avatar
yes stock bottom.
Old Mar 30, 2012 | 06:29 AM
mark21742's Avatar
I ran the high pressure spring in my forged bottom end stroker and hold 50-55psi warm idle, and 75-80psi at high rpms....
Since you have a stock bottom end you would probably went to run the lighter spring. Use the "o" ring that matches the old one in your engine
Old Mar 30, 2012 | 03:07 PM
cajunss's Avatar
thanks for the info!
Old Mar 30, 2012 | 11:30 PM
93Z2871805's Avatar
Veteran: Air Force
What were your bearings set at?
Old Mar 31, 2012 | 09:36 AM
mark21742's Avatar
Honestly I can't remember, I had all the paperwork from the machine shop, but couldn't begin to guess where it might be. I took the shortblock to the machine sho and had him bore it over to 4.030", hone, turn the crank 10/10, new piston and rings , replace a rod, align bore, balance, setup and assemble with new cam, crank and rod bearings. I ported the heads, then had him milled them down to 57cc, and valve job....then I put the cam in and degreed it and bolted everything back together.
The biggest thing is finding a machine shop that knows these motors because they are not like the old sbc.....and yes he has a torque plate
Old Apr 5, 2012 | 09:55 PM
cajunss's Avatar
So if I have the stock bottom run the blue spring?
Old Apr 9, 2012 | 12:18 PM
cajunss's Avatar
Old Apr 9, 2012 | 12:24 PM
KCS's Avatar
KCS
Moderator
Blue spring.
Old Apr 9, 2012 | 12:46 PM
cajunss's Avatar
Thanks!
