Valve Spring Installed Height 1.900 ????
cant remember which ones they are... but there are 2 types... one version has seats built in with them... the other version is just the vale guide seal with no seat
and they are different for the intake and the exhaust....brown and black...cant remember which is which off hand, but its says on the bag...
BTW - I like the OEM guide seals. In 2002 is when GM made them one piece. Brown is EX, black is IN ... it's also stamped on the top of the rubber piece on each seal.
both are OEM and both can be bought at any GM Parts counter..cheap too..
1st design or 2nd design
GM Part #'s
Intake: 12533586 (1st) & 12482063 (2nd)
Exhaust: 12457652 (1st) & 12482062 (2nd)
1st design is without seats
2nd design is with seats
if you use shims with the 2nd design, your shims will go on top of the seats, not underneath..if you put shims under the second design it doesnt seal because you have also shimmed the seal up by that far as well...
I prefer the ones without seats as it allows you to use a much higher quality seat, shims, and you can use a larger diameter seat/shim for larger diameter springs
also, depending on the head and what valve guide is on it... you cant use the all in one 2nd version...if you have the bigger valve guides(like PRC heads have) then they wont even go down... the seal is the same size at the top... the hole for the valve guide needs to be bigger in the case of some aftermarket heads.
So i got the correct tool for measuring...BIG Difference. Now i am showing my installed height at 1.750
So i guess i am too short. It must be the spring seats.
1.750 - 1.140 gives me 610. So realistically with my current setup i should not be running a cam with a cam larger then 560 to stay .50 away from coil bind.
sounds like you need new springs... and possibly thinner seats...dont know how thin your current ones are or if you can even get something thinner or not..
also..if your top measures 1.75...it may be smarter to look into some different valves that get you to the correct 1.8 install height...especially if the heads were bought from a vendor and are currently off the car..
are you 100% positive you measured correctly, and did you check more than one valve?
also, did you properly seat the retainer and locks...sometimes you have to give them a little tap with a socket or a hammer to get them to fully seat...which could make up the height difference..
Did the retainer fit correctly in the micrometer, i.e., the beehive retainers may not sit on the correct measuring surface of the micrometer.
stock z06 heads should be a 1.8 installed height.
Of course, in my case I didn't really have to worry about being so close to coil bind.
IF that is why you see a higher installed height then that is why. I would not just use a valve spring mic, but also maybe a vernier caliper with the height checker on the other end will back up your results.
