LS2 heads interchangeable?
They are talking about using an LS2 with LS6 heads for the GTO and CTS-V in the future in this article. If the LS6 heads fit the LS2, wouldn't it figure the LS2 heads would fit an LS1?
Dan
The LS2 is the product of managers at GM saying:
"We need a new engine for our new (ugly, poorly designed) Corvette. Engineers...you will build us a new more powerful engine with 3-valve heads as a gimmick. You will not have any money to design a new engine block, and because we are cheap and suck you will make the majority of the parts interchangable with the LS1/LS6 platform. The low end engine will utilize the old style heads but we will still be able to give the engine a new name. Thank you for your time."
I'd say that sums it up. Thats why I just went and bought a Subaru. Go to www.alldata.com and compare the problems on a Subaru to those on any GM vehicle. The comparison is a joke. GM is a joke.
It looks like you will be able to use them on the LS1...looking at the size of the heads though, I think they will be considerably taller and shaped differently due to GMs rigging. These heads will probably require new pushods, intake manifold, and exhaust manifolds. They may not even fit depending on what else will need to be removed for extra room. Who knows where the coils are going to go. If you have a 97-98 with the extra exhaust air tubes I have no idea where they would have to be put. Looks like it CAN be done, but only the very brave WILL do it. In GMs defense I think the revised angle for the exhaust valve will allow for more efficient release of exhaust gasses. It's a shame that new pushrod assembly is going to suck power from the engine.
Oh...almost forgot...isn't it supposed to be a 6 liter for the engine with the new heads. Looking at the spacing between the valves I can see it needing the bigger bore just for the valves to not contact the cylinder wall.
As for the three valve setup being "power robbing" I'd be surprised if it's introduced if it isn't considerably better than whatever it replaces. I heard GM had dynos to check all that.
I'm curious, what basis do you have for your comments? Sounds like somebody ran over your dog with a GM product and you've hated GM ever since.
Who cares what the import people think about these motors, the fact is these low tech piston slappin POS engines absolutely kick the crap outta those high revving variable valve timing low displacement "technologically advanced"
import engines. Variable valve timing might be a nice addition on a new engine but, I really don't see any reason right now to get rid of the single cam in block design. Gas mileage wise I don't know what most imports get, probably decent mileage while cruising(30-40mpg?) but, they don't put out the power most V8s do either. I bet that number drops alot when you start floggin on them also. Also most import cars are light which helps those little motors get better gas mileage. I've heard of M6 Fbodys getting close to 30mpg on the highway which is awesome for such a piston slappin V8 junk engine.
I've personally got 25mph in an automatic car with a converter and some bolt ons on the highway before, pretty damn good if you ask me for a probably 400flywheel hp car at the time.
Hopefully, if the new displacement on demand stuff works right it will make those numbers go up even higher.
I think I understand that you are just saying you wish GM would make a max effort street car engine with all the bells and whistles but, why should they when the engine they have is pretty much the baddest thing on the road even against the more advanced engines with only maybe a few exceptions. Most of the time more technology in something means higher prices also. Personally, I think GM is doing just fine with the LS1/LS6 platform. That is why they aren't changing it much with the LS2. Why don't we wait and see how the LS2 and 3 vavle variant perform before condemning them.
Oh well, enough ranting.
