383ci pull vaccum at Wot .!!! help me !
just before redline is around 92 kpa.
I also try the car with only a section off straight 4in pipe and the MAF and it doesn't change nothing on the value off the KPA same drop??
the car only made 389rwhp/377tq on a Mustang Dyno,AF is right on ,max timming is 31°
MAF curve is really smooth
Someone have an idea ?
Here my set-up
Ls1 383ci,11.4cr
TSP stage 2.5 Ls6 head 64cc
LT 1 7/8
Fast 102 intake and TB
85mm Maf
239/247 .621&.632 112lsa+2 on HUC lobe
M6
3.90gear
Try getting a 100mm slot style MAF or going SD and I bet you'd be right up there with 100+ kpa. Also check your air filter and make sure it's clean and not clogged.
