Lunati valve spring kit
Old Apr 12, 2012 | 10:42 PM
cory32690's Avatar
Default Lunati valve spring kit
Got the lunati spring kit 660 lift about to install on my 241 heads how much should I shim the valve spring for a 225/229 581 591 cam on 114 lsa
Old Apr 12, 2012 | 10:45 PM
Gordon0652's Avatar
Do you know why you shim springs in the first place?
Old Apr 12, 2012 | 10:55 PM
cory32690's Avatar
To gain proper seat pressure on each spring when installed and to get proper install heights for desired cam
Old Apr 12, 2012 | 11:00 PM
cory32690's Avatar
Also making sure height is right is to make sure ur compressing spring enough to do job efficiently
Old Apr 13, 2012 | 12:24 AM
2QuikTA's Avatar
I realize you allready have the kit, but wasn't the .660 a bit overkill for a cam that has <.600 lift?
Old Apr 13, 2012 | 11:55 PM
cory32690's Avatar
Yes but I'm going to go eventual go turbo with it plus I wanted a full valve spring kit
