Looking to try and spin a 347 hard need input???
Old Apr 19, 2012 | 10:56 AM
98blueSScamaro's Avatar
Default Looking to try and spin a 347 hard need input???
I have a 346ci LS1 SBE with 243castings ported 54CC chamber's on the head's .040 head gasket... looking to now Run forged pistons and good Rod's. stock crank. Swapping to A Super Vic and fast 4br T/B Running E85 and high 12+ to mid 13's compression. What would be the best pistons , Rod's , ??? Looking for other's input. how high should i spin it? not really doing this to make more power but yet make it last longer and if i can more Hp. old setup put down 500 hp with a slick and 4.56 gear at 7000rpm and held flat to 7400rpm. so my rods are on there last leg as it is.
Setup is M6 car with 4.56 gears and a 28 tire and 3200 LBS
__________________
Old Apr 19, 2012 | 11:02 AM
Burken01's Avatar
I have diamond pistons with Eagle H-beam rods/ with ARP 2000 Rod Bolts.. It isn't the most expensive setup you can get but I think those ARP rod bolts is where you get all the strength from..
Plenty of FI guys running those piston/rod combo's and making 600+
Old Apr 19, 2012 | 12:37 PM
quik95lt1's Avatar
keep in mind longgevity of a high revving RA = less weight.........the less weight you can spin the higher you can spin it and the longer it will last...........if you are sticking with a HR cam there is no reason to expect to see any higher than 7200-7400 if you run very good valvetrain components and design it right......with that in mind a set of compstars and a decent forged piston is all you need...........if its a SR and you want to take it up 8000+ you cant beat a billet i beam like oliver or the crowers even lunati......in that case keep your piston weight down...srp pro series are light and cheap.....shop for a piston in the 38x-42x gram area........lighter the better..........i run a callies lightened crank, oliver billets and srp pro pistons in my LT1 shortblock and im taking it 8000-8200 every pass with no issues at all......
Old Apr 19, 2012 | 01:17 PM
Yes i know the lighter the better. and i know all about valve train and H/D to Solid setup. and only the best springs i have pac's now lifters running morel race link bars now with a hyd cam due to being stock bottom end. really looking nto a solid roller just trying to see how highmost spin them or have. this way i can pick a cam to suit my heads and setup.
So srp makes a good light piston ??? and i may run a baby dome to bring up the compres. checking on them now.
Old Apr 19, 2012 | 03:15 PM
quik95lt1's Avatar
yes im running an srp 7 cc dome in my LT puts my compression up around 14.7:1 .........and in reality you use good parts 8+rpm is not unheard of
Old Apr 19, 2012 | 03:33 PM
what CC are the cambers on your heads? I really want to make use of this E85
