Lean codes
Old Apr 19, 2012 | 07:44 PM
Formulaone02's Avatar
Default Lean codes
02 firebird formula, LS1.... No problems until I added a K&N cold air aftermarket MAF housing, a superchips cortex tune, SLP exhaust, and bypassed the TB coolant..... Now I'm getting lean codes on both banks... Any help would be much appreciated, I've cleaned the MAF sensor from extra oil from the filter and checked for vacuum leaks none found /:
Old Apr 19, 2012 | 08:35 PM
Darkman's Avatar
Is the tune reversalible?
Old Apr 19, 2012 | 09:34 PM
Yes and I've tried that, code came back
Old Apr 19, 2012 | 09:41 PM
Darkman's Avatar
Have you tried reversing what you did on the MAF?
Old Apr 19, 2012 | 09:45 PM
I just replaced the housing and the stock is long gone
Old Apr 19, 2012 | 09:49 PM
Darkman's Avatar
Okay. I don't see anything on the list of things you changed that would trigger lean codes other than the tune and something wrong with MAF setup. If you think those have been eliminated, that leaves the traditonal causes of lean codes - check the fuel level, the fuel pressure, and/or change the fuel filter.
File Type: pdf
Old Apr 20, 2012 | 10:48 AM
cruisin'73's Avatar
Default Lean Code
Darkman, thank you for posting that awesome diagnostic procedure, where did you find it? I have been intermittently getting those code in my Yukon. So when I was scrolling through recent posts and saw this one I thought I would check it out, and I am glad that I did. Thanks!
Old Apr 20, 2012 | 10:51 AM
Fuel level is good, I change the fuel filter every other oil change the only thing I'll have to check is fuel pressure, I've even done a fuel treatment and I'm still getting the codes
 Michael S. Palmer
Old Apr 21, 2012 | 07:49 AM
Darkman's Avatar
Post the code numbers.
Old May 3, 2012 | 08:07 AM
P0171 and P0174
