Advice on crank
Old Apr 20, 2012 | 05:57 PM
Ls sn95's Avatar
Default Advice on crank
What crank to run in my lq4 to support I've seen and heard of plenty of guys making this power on the stock ls1 crank it's goin to be spun by a F1R at 20 25 psi is that much boost goin to put to much pressure on the stock crank,if so what crank do I go with
Old Apr 20, 2012 | 06:00 PM
ANTICOP RAM AIR's Avatar
same crank casting.. LS1 is drilled in the center and balanced for a different rotating assembly... both cranks are good to well over 800 hp... Id see the only advantage being with the LS1 crank but only cause its probably a little lighter and can rev higher... if you plan to really wind it up...
Old Apr 20, 2012 | 06:08 PM
Ls sn95's Avatar
Well this is my first ls style motor so I can put the ls crank in the lq4 the plan is to go to a 408 CID will this work
