No oil pressure
. I'll be the first V8 Dodge to break 20mpg bahahahahahahahahahahahahahaha
.So.....fired up the car last night and had 40psi. Let it run while I got all the air out of the radiator/block and stayed the whole time. Shut it off and let it cool. Went out a few hours later and still great pressure. Go to take it for gas this morn, get to the gas sation about a mile away and the gauge is fluttering again. Take it back home and once i get home....0 psi.
Maybe pull it apart and check this or put a new pump in. If you were going to do bearings, seems like you should pull the motor and have the crank resized to obtain the proper clearances.
