Why reverse split stealth cam is better?
Old Mar 29, 2004 | 01:36 PM
99ssleeper's Avatar
GT2-3 is the ultimate sleeper cam 208/220 on a 118.5 LSA and will idle and drive like stock when tuned.
That one drives and idles like stock totally untuned. The ultimate sleeper cam!
Old Mar 29, 2004 | 02:35 PM
PREDATOR-Z's Avatar
What's your goal with the car?
What's the main concern? Idle? Idle w/o tuning?
IMO unless you are trying for a sleep sound there isn't really much reason to go 115 LSA or any of the cams 224/220 or 222/222 your considering IMO. I think you'd be better off with a custom 224 XE-R on a 115 LSA than either of the cams mentioned on a 115.
Have you ever heard a properly tuned 224 XE-R on say a 114 idle? This will be a better cam power wise than the 222 XE-R on 115 or the 224/220 XE-R on 115. I asked Paul at TR about the 224/220 idea vs 224/224 almost two years ago. Paul felt at the time there wasn't any benefit to taking a 224/220 over a 224/224.
BTW my 224 XE-R on 113 LSA w/tuning is tame idle wise.
Nice thread BTW.
However may I point out that the stealth II, MTI cam is 224/220, .576/.581 116 lsa and not a 115.
Stealth I is a 220/220, .581/.581 115 lsa and I've heard that one, iddles much better than a similar 220/220, .581/.581 114 lsa. That is at same idle RPM.
Also notice that the stealth II has a regular lift split on it: which means it is an opposite reverse split cam lol joking
That is what gives this cam its peculiar characteristic, is capable of 420+ rwhp and pulls till or beyond 6800 rpm.
Old Mar 29, 2004 | 02:59 PM
BigTex's Avatar
Originally Posted by PREDATOR-Z
(stealth II) is capable of 420+ rwhp and pulls till or beyond 6800 rpm.
With the stealth II being on a 116 LSA, with 0 advance, it has a 116 intake centerline. Compare that to a common TR224 114 cam with +4 advance that has a 110 intake centerline. Does anyone think that 6 degree difference between intake centerlines would make a difference? I do. From what I understand, it should hinder low end torque and extend power to higher rpms.
So I ask this question: What would the results be by taking the Stealth II cam and advancing it 6 degrees to the same 110 ICL as the TR224 cam? Stronger low end torque and lower peak rpm power with the same stealth characteristics of its 116lsa?
Old Mar 29, 2004 | 03:08 PM
DenzSS's Avatar
Yup, the difference between the centerlines is going to make a difference and I think you're going in the right direction. Advancing it that much is going to have an effect, I'm just not sure it will be a net positive. It would be worth a shot, although +6 is lot of advance IMO. Would be an interesting experiment regardless.
Old Mar 29, 2004 | 03:20 PM
BigTex's Avatar
I wasn't trying to get hung up on 6* of advance being too much / little. I think advancing it 6 may be too much for a car. I am more interested in the net results on peak power and low end torque by having that cam advanced some. Personally, I'd love to see a comparison of dyno numbers by only changing the advance of a cam.
Old Mar 29, 2004 | 03:58 PM
Camaro SS 2002's Avatar
How much RWHP can I expect from the Stealth I cam(220/220 .581"/.581" 115) and a GOOD tune, on stock manifolds??
Thanks...
Old Mar 29, 2004 | 04:02 PM
DenzSS's Avatar
I've seen roughly equivalent cams make in the 370s with the stock manifolds and cats.
That was with a very good tune and a very good cam. stock heads, slp dual dual, whisper lid.
It made a truckload of torque.
Old Mar 29, 2004 | 05:26 PM
black_knight's Avatar
Thank you, DenzSS, that does clear up a few things. I was familiar with the concept of valves and events (I still appreciate the info, though), but hadn't considered that leaving it open too long could cause the pressure wave to take a/f OUT of the cylander. It also makes sense that a larger cylander would take a differant amount of time to fill.
Great post: don't worry about the rambling part. Keep it coming!
Old Mar 29, 2004 | 05:45 PM
Iv_z28's Avatar
Me too. Sounds like magic - you advance a cam with high LSA and get the powerband where you want it and great idle too. Why do we even have straight up cams in daily drivers? - take TSP231/237, put it on 118lsa and advance it back to 110 intake centerline.
So why didn't they use advance in stealthII at all??
Old Mar 29, 2004 | 05:53 PM
I'm almost SURE it doesn't work like THAT!
Old Mar 29, 2004 | 05:55 PM
Whoa, I wouldn't expect that much! MTI Stealth cam.
Old Mar 29, 2004 | 06:00 PM
  #32
DenzSS's Avatar
I don't know if the Stealth can put that much out, but it should be able to come close. Good tuning and good cam design go a long way.
Old Mar 29, 2004 | 06:04 PM
  #33
Do you think the MTI Stealth cam could put down 360 at the least, with a Maganaflow catback, TSP Lid, stock manifolds, and importantly a GOOD tune?
Old Mar 29, 2004 | 06:18 PM
  #34
DenzSS's Avatar
Yup. I don't see any problem at all putting down at least 360rwhp with a good tune.
There aren't that many people doing cams without headers, but I've seen very good results.
Old Mar 29, 2004 | 06:20 PM
  #35
Iv_z28's Avatar
So where is the catch?
With bigger durations stress on the block shouldn't be an issue, right?
I'd really like to get a feedback from somebody at MTI on their rationale behind StealthII
Old Mar 29, 2004 | 06:21 PM
  #36
LT's are not legal in California, so I can't go that route. The Stealth cam will definitely pass emissions and 360 rwhp'ish is plenty enough power for me.
Old Mar 29, 2004 | 06:24 PM
  #37
Does the MTI Stealth I and Stealth II cams make about the same power?
Old Mar 29, 2004 | 10:06 PM
  #38
Colonel's Avatar
A few points about the Stealth cams (the specs of which were a product of my imagination, FWIW.)
The lift of the Stealth II is listed as .571/.581 on the Stealth II. I believe this to be incorrect. I believe it is .581 on both sides. That's the way my Stealth II (the very first one) was supposed to be and I don't see why such a tiny meaningless change would have been made. Besides, last I checked, the XE-R lift for a 220 OR 224 lift lobe was .581...and that's the lobes this cam has.
Why are the Stealth cams straight up instead of advanced? In short, to make better power up top. I wasn't looking to make power down low since I envisioned a 5200+ shift extension (my SS4000 stall converter has an SE of about 5350.) I was looking to make maximum ET with a silky smooth idle. This cam pulls like a beast all the way to roughly 6800 depending on setup. My shift points are 6700-6750.
Which is faster, the SSI or the SSII? They are very close. Assuming a great exhaust system (LT headers, cuttout, high flowing cats or no cats at all) I'd take the II since it should make slightly better power to a slightly higher RPM than the I. With a lesser exhaust I'd take the I. Either should idle about the same.
BTW, the Stealth II and MTI LS6 heads were good for an 11.20 and 121.5 MPH with a 3525 lb raceweight, stock 3.23 gears, and factory wheels. It churned out 423 RWHP.
Old Mar 29, 2004 | 10:47 PM
  #39
Wow, very informative!!! Im my scenario I want to put the Stealth I cam in my 02 SS M6, but keep the STOCK manifolds for smog reasons in California. Colonel, with my mods listed below, what approximate RWHP can I expect??
2002 SS M6
*TSP Lid
*Magnaflow catback
*MTI Stealth I cam(valve springs, Ti retainers, hardned pushrods, gasket kit)
*Very important, a GOOD dyno tune
Thanks...
Old Mar 29, 2004 | 10:51 PM
  #40
DenzSS's Avatar
Just as a bit of advice, keep the stock pushrods. It is a lot easier and cheaper to replace a bent pushrod than to take out a valve or a lifter.
