Low oil pressure
Old Apr 29, 2012 | 04:29 PM
C5LS1's Avatar
Default Low oil pressure
Hi everyone I'm not sure if what I have read here and there on the web is correct about oil pressure.
My LS1 always had 42-44 PSI at 700rpm(idle) and it suddenly is at 30-32.
At crusing RPM(1600-2k) it indicate 40-42 PSI and never go higher than 59-60 at WOT.
Using same oil as always;Mobil 1 5w30.
Stock gauge if it matters.
The engine also ''knocks'' sometimes,does'nt burn oil and no leak.
Old Apr 30, 2012 | 02:50 PM
C5LS1's Avatar
Bump.
Old Apr 30, 2012 | 06:16 PM
sfc rick's Avatar
How long since last oil change, it still is within spec as is.
Old Apr 30, 2012 | 07:11 PM
blacknyellow's Avatar
I had the same deal with my old motor, had 150k miles of not so easy driving and eventually my oil pump went out, to this day I believe it was the pickup tube o-ring. I changed the oil pump because I figured that's what it was since it was having low oil pressure. I was unknowledgeable about the weak oring in ls1s. This helped for a while but it eventually went out again and went to 0psi and I didn't notice it in time, and it was a really hot day so it destroyed my motor. I would suggest you address this. I would get a new oring and pump, but first make sure you have fresh oil and your gauge is still correct.
Old Apr 30, 2012 | 07:13 PM
ssteven's Avatar
So oil with say 2500 miles from the last change will show lower pressure?
Old May 1, 2012 | 01:05 AM
C5LS1's Avatar
About 25 miles since last oil change lol.The gauge seems to be working correctly because it goes up as soon as I hit the gas a bit and goes down when I slow down.
I know hotter temp lowers oil pressure but the car rarely goes over 200F(with fans never working but that's another subject).
How long does it take to your average mechanic to change the oil pump? I am considering an LS6 pump right now.I'm used to work on smaller engines.
Old May 3, 2012 | 10:59 PM
C5LS1's Avatar
Bump.More inputs would be nice.
Old May 3, 2012 | 11:25 PM
Grimes's Avatar
This actually happened to me last summer, and I took a chance and just changed my oil and filter. Somehow the problem went away and never came back. Not sure what the hell happened, but it is worth a shot to try.
Old May 3, 2012 | 11:48 PM
C5LS1's Avatar
I had a ''cheap'' oil filter and now I'm using a FRAM.Don't know if they are REALLY good I've heard mixed opinions about them.
Old May 4, 2012 | 05:18 AM
Grimes's Avatar
well see what happens if you switch filters. the filter i replaced was a stock ac delco one. I've had no problems with them other than this last one.
Old May 4, 2012 | 07:01 AM
crainholio's Avatar
I'd change just the filter as a next step, grab a Wix and top off the oil.
If you look at pictures of the Fram filter's internals, you'll realize they are junk.
Old May 4, 2012 | 11:54 PM
C5LS1's Avatar
Buying a GM OEM filter tomorrow.
Old May 7, 2012 | 03:17 PM
C5LS1's Avatar
I noticed that it takes maybe 1-2 second for the pressure to start climbing on the gauge...
Old May 7, 2012 | 03:19 PM
94LT1TA6spd's Avatar
I always use Mobil 1 filters they work well IMO
Old May 7, 2012 | 03:23 PM
C5LS1's Avatar
I'm still using the FRAM but I'm buying a GM OEM tomorrow we'll see.
Old May 7, 2012 | 04:38 PM
Rare96LT1Formula's Avatar
I'm having oil pressure issues myself. It's normally ALWAYS at 40. Lately at idle i'm barely hovering over 20 on a warm day. I just swapped in an LS6 intake, Stepped LT's w/ TSP ORY, MSD wireset, NGK Tr55's, and AC Delco Fuel filter. Gave it a fresh oil change with 6 quarts of pennzoil platinum 5w30 and a K&N oil filter. Not sure if any of the mods played a role, but something is going on here...
Old May 7, 2012 | 05:19 PM
Grimes's Avatar
The first time you start after an oil change? That's pretty normal. you can cut down on the time by filling up the filter before you screw it on.
Old May 8, 2012 | 03:18 AM
C5LS1's Avatar
No not only the first time.It always does that...well always on a col start.I can't tell right now if it does that too when hot.
Old May 8, 2012 | 06:44 PM
crainholio's Avatar
With every properly-running LS engine I've seen, the oil pressure gauge snaps on startup from 0 to whatever cold idle oil pressure is (usually just over the 1/2 point on the gauge in warm weather) and stays there while the engine is idling up to temp. No twitching of the pressure gauge needle unless the throttle is blipped.
The two LS engines I've seen with oil system problems (one was a damaged pickup o-ring, other was unknown) the pressure gauge was twitching, even while the idle RPM was steady. Gauge was also slow to rise from zero during the initial startup.
These are tell-tale signs to look for...how does your gauge look at startup and idle? (edit: after you get a decent oil filter installed)
Old May 8, 2012 | 06:50 PM
Transmission Perform's Avatar
How many miles? It's already knocking?
