853 ls1 heads
Old Apr 29, 2012 | 10:41 PM
66vert's Avatar
Default 853 ls1 heads
are they worth a crap on a 5.3?
Old Apr 29, 2012 | 10:50 PM
butler's Avatar
They flow a little less then a 243 but they aren't bad. Pull the valves get a porting bit for aluminum and do some pocket porting. Clean up the exhaust runners. I have done it. Ran 10's.
Old Apr 29, 2012 | 11:21 PM
66vert's Avatar
excuse my ignorance, but what is "pocket porting". should I port the intake side as well as the exhaust side?
Old Apr 30, 2012 | 08:39 AM
bww3588's Avatar
Only down side, is if they have the "notch" you can't run anything but stock graphite gaskets.
Old Jul 30, 2012 | 12:47 PM
Blesvik Racing's Avatar
http://www.summitracing.com/parts/FEL-26192PT/
You can use this gasket!
Old Jul 30, 2012 | 01:46 PM
wildcamaro's Avatar
Using those heads will drop compression...they will flow more than 5.3 heads but the lower compression will prob knock you down to like 9:1
