85mm Throttle Body
Old May 3, 2012 | 05:25 PM
fairc67's Avatar
Default 85mm Throttle Body
I just got me a 1999 trans am ws6 6 speed, the only upgrades are only surpose be the exhaust, i was wondering if i put an 85mm Throttle Body on it would it have to be reprogrammed. any advise would be thankful.
Thanks
Old May 4, 2012 | 12:44 AM
PREDATOR-Z's Avatar
It is pointless to do so. First see if you have LTs and adequate exhaust system. Then a LS6 intake. If you are set on running bigger than OEM tb, check TPIS for 90mm conversion.
If you're set on tb mod only, then port the OEM.
