243's vs 317's
Reason I ask is i picked up a LQ9 6.0 for a S10 LS\T56 swap. my friend has some nice clean 243's off a tbss that he's no longer using. what are the pros and cons of the different heads on an Iron Block 6.0? this build is going to be a cam and bolt on truck at this point in time with tubo added later down the road. do the 317 flow about the same as the 243? im not wanting to raise the c.r with the mind of a turbo sometime down the rd, would i be safe running a thicker head gasket with the 243' and turbo? or just say forget it and run the 317's
It all depends on what your build is and what sort of compression you want. For N/A, definitely go with the 243s. For boost, depending on the rest of your bottom end you might want to go with the 317s for lower compression.
By the time you buy the bolts and pay for the machine work you might be better off getting some cheap scat i beams, etc. as they have larger arp bolts in them. You can get them in full floating pins for aftermarket pistons or press fit stock type. Not sure how far you want to take this thing though.
