Compression check
So I replaced the coil pack on that cylinder. Had all the fuel injectors cleaned and flowed. They checked out just fine. Replaced the plug wire. Pulled the spark plug and it looked fine. Still a bit of a miss and lower temp on that cylinder.
So I'm thinking compression test on that cylinder.? Do I have to pull all of the spark plugs to get an accurate reading? Or can I just pull one of the other plugs and compare PSI wise?
How much is typical compression PSI wise? Never did a compression test on a LS engine.
Many many moons ago we were taught on carbed SBC engines you pulled all the plugs and held the throttle blade open as you crank the engine..
In a compression test you're usually looking more for consistency among cyls than some specific # (which is why you want it to spin at the same RPM for all cyls... consistency). Any number of things can affect the absolute #; temperature, humidity, the cam you're using, whether it's advanced or retarded compared to other installations, valve adjustment or hydraulic lifter status, and so on. For a gross rule of thumb, 5% consistency or so among all 8 is ideal. 10% or greater variation is an indication of possible fornication and calls for further diagnosis.
A pump gas engine should show no more than about 200 psi, usually. 180 - 200 is pretty typical. A way high # compared to the others on only 1 cyl, is a classic sign of a cam lobe down, usually exh. A longer duration cam can drop it ALOT; sometimes as low as 150. 2 cyls next to each other with low #s is a blown head gasket (they most often blow where they're the weakest / narrowest and the pressure differential is highest, which is between adjacent cyls, NOT between a cyl and the coolant jacket). And so on.
Doesn't too much matter what kind of engine. Air is air, fuel is fuel. That's what you're really working with, not the brand of the castings, as far as what the #s should be. Fuel doesn't care whose castings they are, or how many cyls are in it, or any of the rest of that; it detonates at pretty much the same pressure in anybody's.
And of course unplug the big connector(s) to the coils for kinda the same reason.
Both of these are universal common procedure for this testing.
Has the intake been off since them?? Outside chance there's a leaking intake gasket on that cylinder...???
