Rod Question...
Although I'm relatively new to LS motors, I've built close to a dozen other motors. I recently got a killer deal on an almost complete LS-1 that was sold with the warning that it had low compression in one hole and a lot of trash in the pan. After tearing it down, the only oddities I've found were: #1 intake lifter was different than the other 15, #7 exhaust valve seal was MIA, number 7 rod had "7" stamped into the shank (no others were numbered), and all of the rod bearings were so loose the inserts literally fell out of the rod and cap! Pistons and rods are stock but it has ARP 8740 rod bolts. Absolutely no bearing crush at all, I'm guessing that's not normal? The previous owner had removed and cleaned the pan, screen, and oil pump. All the journals looked good, the rod bearing shells (STD) were "OK" other than being loose, and the mains bearing shells (STD) had some signs of particle embedding but the journals were good. ASSuming the rods aren't junk, I could get it back together for the cost of new bearings...
mind if i ask how much you payed for this motor?
are you planning on reusing everything that is still good?
Maybe the Rods were improperly re sized for the arp bolts.
