Oil pump question
Old May 16, 2012 | 11:21 AM
Hauler's Avatar
Default Oil pump question
I've read on this forum that 98 T/A oil pumps were not built as well as
later models. My bird has 137k on it, and oil pressure cold is around 40-45psi, hot drops to around 20psi. My question is should I replace the oil pump, and can it be change without pulling engine. Thanks for any help!
Kenneth
Old May 16, 2012 | 11:28 AM
PREDATOR-Z's Avatar
Could be your bearings are going bad. But to answer you Q, Yes you can change with motor in car.
http://www.ls1howto.com
Old May 16, 2012 | 11:35 AM
Hauler's Avatar
Thanks for the quick response PREDATOR-Z ! Thanks for the link as well.
