re-build
Old May 16, 2012 | 09:12 PM
King23's Avatar
Default re-build
Hey guys getting ready to tear my car down and start building her heads cam all supporting mods all that good stuff new seals basically all new top end but it has 160,000 miles on it is there anything u guys would suggest checking/replacing while im in ther car still runs strong always taken care of i did plan on new piston rings though any advice would help thanks
Old May 16, 2012 | 10:06 PM
conan's Avatar
Timing chain, oil pump, lifters on your list ?
Old May 17, 2012 | 10:41 PM
King23's Avatar
yep doe got the ls7 lifters ls2 trays getting ls2 chain and ported ls6 pump
Old May 18, 2012 | 05:53 AM
mark21742's Avatar
Take your heads to the machine shop and have a quick clean up mill and valve job.
Old May 18, 2012 | 06:57 AM
BIG_MIKE2005's Avatar
Forget the ported pump unless you wanna keep extra oil in it. A normal stock LS6 oil pump will do you just fine & save you some cash. The ported ones tend to suck the pan empty sometimes at WOT if you dont have extra oil in there. Just a word of caution.
Old May 18, 2012 | 08:49 PM
King23's Avatar
thanks guys i had no idea about the ported oil pump thanks ill be running the tsp tsunami cam which just arrived today :] and ill be running new prc 2.5 5.3 heads
Old May 20, 2012 | 08:24 AM
You'll like the bump in compression from the 5.3's. I love it with my little cam.
Old May 20, 2012 | 10:24 AM
garygnu's Avatar
with a big cam like that get some comp cam trunnion bearings from TSP.consider some kaltech rod bolts.
Old May 20, 2012 | 10:33 AM
You mean Katech rod bolts
Old May 20, 2012 | 10:40 AM
PREDATOR-Z's Avatar
Do a compression and leakdown test. That will give you an idea on the health of your block. From there you can take a more rational decision about if it is wiser to rebuild or not.
