LQ4 to LS2 difference?
Old May 26, 2012 | 11:15 AM
solareclpse2000's Avatar
Default LQ4 to LS2 difference?
ok guys i have a 2000 z28 i was told it had a 6.0 ls2 in it. as i started to learn some more about the ls engines i found the heads (casting number 241) intake, throttle body, injectors, the whole top end and water pump, are all LS1. i ran the casting numbers on the block ( 12551364) and it came up LQ4/LQ9 truck 6.0 iron. the fact in the end is the thing is a beast. it was built by an ex GM engine tech and i guess he did a budget build 6.0. cam, rods, pistons, ect my question is what is the difference of the LQ4 and the LS2 bottom end. (besides the iron block) and are they completely compatable with LS1,LS2 parts? obviously the heads and up are interchangable. but is the bottom end the same?
also what are yalls thoughts of an LS1 top on a LQ4 bottom? i would think the compression would be higher with the 241 heads. but i know cars well. been working on cars and trucks a long time. and i know basics of the ls series motors but not much. just learning along the way. thanks guys
Old May 26, 2012 | 11:35 AM
dodson55's Avatar
all lq4 run dish pistons ls2 run flat top 04 down lq4 run the ls1 style rods 05 up lq4 run the same rods as ls2 the crank is basically the same as long as its a 01 up lq4
Old May 26, 2012 | 02:08 PM
thompson's Avatar
The ls2 has knock sensors on the sides of the block instead of the valley like the Gen III LS1 and LQ4 like you have. The Cam position sensor is in the rear of your motor originally (ls1) as well as the LQ4 and the LS2 will use the front cover for the cam sensor.
bore/stroke/rod length are the same between the two and connecting rods do change depending on year from pressed pin to floating. With the LQ4 pistons and your 241 heads you will be close to stock compression give or take depending on the head gaskets, if the heads have been surfaced and if the block has been decked.
Old May 27, 2012 | 09:44 PM
I have a sensor on the passenger side of my block just above the oil pan. Above the oil level sensor. Is this a knock sensor? If so than how is it an LQ4? Th casting number says lq4/lq9. The pistons rods and cam hav already been changed n the setup sounds pretty good.but its impossible for me to identify internals.
I do know th pistons are flat top. Not sure what brand or if they are freefloating pins. I Jus had th Trans out and saw no sensor in the rear. Where exactly is th sensor located on front ls2 or rear ls1?
Old May 27, 2012 | 10:01 PM
outkast6991's Avatar
Cam sensor is on top of the block behind the intake next to the oil pressure sending unit on lq4/9's. The sensor you mention on the pass side of the block is crank position sensor most likely
Old May 28, 2012 | 04:26 AM
PREDATOR-Z's Avatar
The obvious difference is (LQ4 iron block), LS2 Aluminum. can it get easier?????
