Valvetrain PROs needed!!! PLEASE this is gotta be somthing new in the LS1tech forums
[/IMG]Trending Topics
Second, did they touch the valves or the seats? Find out from the shop exactly what was done with the valves and seats.
Third, examine that rocker carefully for any differences from the others (lost bearings).
Fourth, bring that cylinder to zero lash (TDC on the firing stroke). Can you lift the rocker tip and make it "tick" "tick" by hand? To do this, don't use a lot of force as it may depress the lifter plunger, you only need to feel for looseness.
2. Yes they did they ported and replaced valve guides and seals, speaking of i checked that same spring this morning and inside it had piece of the new valve seal the little springy part ripped off ill post pics after work.
3.Rocker is fine i compared with others as well i installed on other cylinder and was solid..
4. I tried that and yes i can wiggle it with my hand it literllay has no tension but the rocker is toqued on!
what bothers me is that we cant find the right guides for these heads... so i found some with the specs he wanted and custom fitted them so im completely lost right now and broke now..........
[/IMG]
[/IMG]
