Mods Advice, HELP!
Old May 30, 2012 | 02:23 PM
JRSIV's Avatar
Default Mods Advice, HELP!
I don't want to jump the gun as I don't have the 2000 Camaro SS yet. Agreed in principle and it's a matter of paying and picking the car up. Before doing that, I have a question for you out there, curious what people's opinions are:
Looked at this particular 2000 Camaro SS, it looks good, seems to run good and drive well. However, it's been modified with heads and cam and whatnot, but the seller says that the previous owner had these things done 20,000 miles ago and doesn't have the receipts. Says he owned the car since 2006 and the mods were just done then (at about 40,000 miles, there are 60,000 miles now).
The listing says that the car has:
Patriot Stage 2 Heads - can't verify that they are Stage 2 but did see a Patriot stamp on them when the hood was popped.
patriot dual gold valve springs - ?
titanium retainer - ?
texas speed and performance magic stick cam - can tell there is a cam from how it runs/idles, can't verify that it is Magicstick and what specific model without receipts
ls7 lifters - ?
ls2 timing chain - ?
yella terra 1.7 roller rockers - ?
comp hardened pushrods - ?
slp high volume oil pump - ?
slp under drive balancer - ?
slp 1 3/4 long tube headers with off road y pipe - can see with hood popped and from looking underneath even though it wasn't jacked up
qtp eahaust cutout - not worried about it but couldn't see that far under car without it being jacked up
flowmaster cat back - certainly sounded like the good old Flowmaster
tick performance clutch master cylinder,new 02 gm slave,spec stage 3 plus clutch - certainly didn't feel like a stock clutch at all
slp sub frame connectors,spohn rear control arms and panhard rod - couldn't see underneath
c6 corvette wheels, new brakes and drilled and slotted roatars - does have these
So as you can see, I verified some of these things from looking/listening but what about the others? How would you feel about buying something like this with 60,000 miles and no receipts to verify what you exactly have?
Thanks,
John!
Old May 30, 2012 | 02:29 PM
mark21742's Avatar
Only thing is be worried about is the valve springs.....it is probably time to change them out for new ones and with the valve cover off you can use a dial indicator and degree wheel to figure out exactly what cam is in there....chances are this guy is telling the truth, but the way some people try to screw other people makes me question sellers too.
