Wisco piston help
Old Jun 5, 2012 | 11:12 PM
Joshhoskins's Avatar
Default Wisco piston help
I had a 408 build with wisco pistons and just want to verify that the correct CC got install before I button it up. Is there a P/N stamped on the piston it's self and were is it located? Thanks in advance.
Old Jun 6, 2012 | 01:02 AM
01 WS6 6.0's Avatar
Should be right on top of the piston are they custom pistons?
Old Jun 6, 2012 | 05:30 AM
PREDATOR-Z's Avatar
They are called WISECO
Old Jun 7, 2012 | 10:24 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Any of their off the shelf pistons should be engraved with the part number (may be one digit off or an extra digit added) on the top/crown of the piston!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 8, 2012 | 07:52 AM
ausls1's Avatar
As said should be clearly marked on the top off the piston, i know mine were.
Old Jun 11, 2012 | 07:28 AM
briannutter's Avatar
shelf stocking have pin stamped numbers...usually 4 digits followed by an a/f/or x then 3 more numbers for the bore size.
Custom pistons don't have a number stamped in the top, so you may have some of those.
If you take a photo of the pistons, I may be able to tell you more.
