best HP for cam only motor
Old Jun 11, 2012 | 04:01 PM
Bleu's Avatar
Default best HP for cam only motor
I am going to build a genIII 346, I was wondering what the best HP&torque #s that I could hope for on a cam and bolt on's only motor except for longtubes. with all of the best mods you can get and a very good tune. I want all usable power & torque in the low-mid range of the powerband.
Also can one of you cam guys spec me a cam? I'm looking for as much power down low as possible.
I basically want to know how much power as possible from a N/A 346 without nitrous.
all help is much appreciated. thanks.
Old Jun 11, 2012 | 10:57 PM
intenseblue's Avatar
You'll make more of what you want and cheaper with longtubes.
Old Jun 11, 2012 | 11:25 PM
Blk98Vert's Avatar
First off, get longtubes. Second, I have seen 400rwhp through shorties but the setup was max effort IIRC (FAST intake, true duals, M6, stock gears etc)
Old Jun 12, 2012 | 12:41 AM
Bleu's Avatar
I know....but its going in my jeep tj, and there is no way to fit longtubes.
Old Jun 12, 2012 | 12:47 AM
Comp 212/218 if you're dead set on an aftermarket cam. Will make more power everywhere over a stock cam from what the silverado guys say and will work with the stock torque converter
Old Jun 12, 2012 | 12:52 AM
lemons12's Avatar
Insane low-mid range power and high/est peak Rwhp doesn't go hand in hand.
I would talk to Pred Z, IIRC he has made some nasty down low torque monsters.
Old Jun 12, 2012 | 01:01 AM
studderin's Avatar
GM hot cam
Old Jun 12, 2012 | 04:23 PM
Bleu's Avatar
thanks Lemons, I'll check it out.
