need help with my setup
Old Jun 13, 2012 | 09:17 PM
spiro27's Avatar
Default need help with my setup
have a 01 trans am ws6 6spd. im doing a 226 234 eps cam with trick flow 215 heads 1.7 yella terras. 1/78 arh headders. have a few questions. do i need valve cover spacers to clear rockers from hitting valve covers. i was told i would need 42lb injectors. where can i get injectors for good deal. and would a fast 102 intake and tb be worth it on my setup? and if so whats a good price for it thanks for the help.
Old Jun 14, 2012 | 05:16 AM
spiro27's Avatar
What spark plug should I run and what gap should it be at
Old Jun 14, 2012 | 06:27 AM
Darkman's Avatar
A FAST 102 will make more power with those heads than the stock intake.
I would run NGK TR6 (Part No. 5141) gapped at 0.040 inch, or longer life NGK TR61x (Part No. 3689) also gapped at 0.040 inch.
I am not sure on the valve cover clearance - the TFS 215s have more clearance for rockers. My Jesels, which are shaft mounted did not require a spacer.
Old Jun 14, 2012 | 10:24 PM
spiro27's Avatar
i gess i try the rockers and turn the engine overs and see if they hit with valve covers loose.
ill keep looking for the injectors and fast intake and i look for thouse plugs
Old Jun 16, 2012 | 12:07 PM
spiro27's Avatar
has anyone run yella terra rockers and tfs 215 heads do the need valave cover spacers.
