15W-50 too thick??
Old Mar 31, 2004 | 10:56 AM
99PTA's Avatar
Default 15W-50 too thick??
I waswondering if Mobil 1 15W-50 was thick of an oil on a basic bolt on Trans Am?
Old Mar 31, 2004 | 11:29 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default viscosity
Use a lighter weight. Clearances are tight on these engines - they are designed for 5w30. A 15w50 will take longer to thin out on cold start and get to critical areas of the engine resulting in greater wear. Gas mileage will suffer also from the increased rotating friction a higher viscosity oil.
Steve
Race Engine Development
Old Mar 31, 2004 | 11:39 AM
Noyzee's Avatar
8 second mod
id use a 5-30 or st 30. unless you get a different pump.
i run 50 wiegt in my car
Old Mar 31, 2004 | 12:39 PM
99PTA's Avatar
A local oil place..... suggested mobil 1 10w-30. is that good or shoudl i just get 5-30
Old Mar 31, 2004 | 12:43 PM
Assassin's Avatar
castrol GTX 20/50 here!
Old Mar 31, 2004 | 12:57 PM
SSCamaro99_3's Avatar
I was running a mixture of Mobil 1 0W-40 and 15W-50. 4 parts to 2. Did the same substituting 10W-30 for the 0W-40. I am switching to Redline 10W-40.
Old Mar 31, 2004 | 01:22 PM
PlainwhiteZ28's Avatar
unless you have a powerstroke in your car, Id stick with 5w30 or 10w30
Old Mar 31, 2004 | 02:37 PM
stealth's Avatar
I use Mobil 1, 15W50.
Old Mar 31, 2004 | 02:38 PM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
or a stroker motor that runs 2.5 - 3 thousandths bearing clearance.
Old Mar 31, 2004 | 02:43 PM
stealth's Avatar
I assumed one could tell from my sig that, since I am using Lunati, I was running ~.0028 to .0030 main bearing clearance. THey recommend .0030 out of the box.
Old Mar 31, 2004 | 06:21 PM
Damian's Avatar
LSX Mechanic
15w50 would be ok for a high mileage motor that see's a lot of abuse. IE: 90-100K+ miles. A buddy of mine runs 20w50 in his 98 motor w/ 125K on it, sprays it daily with no problems.
10w30 at the very least. 5w30 is way to thin IMO, that **** is almost like water before heating up...
I used 10w30 Valvoline in my 98 shortblock from day one, beat the living **** out of it for 40K miles, and upon teardown my internals looks almost brand new. Bearing wear was almost invisble...
Old Mar 31, 2004 | 10:37 PM
ataylors's Avatar
It also has alot to do with what your climate is like. I have been running Mobil 1 15-50 in my Grand Prix GTP since 98 with no troubles
Old Mar 31, 2004 | 10:39 PM
sickfive55's Avatar
i use amsoil 0w30 is that bad? my car runs good...
Old Apr 1, 2004 | 12:08 AM
jimmy 2 Times's Avatar
i was told that i should run 4.5 quarts of 5w30, and 1 quart of 15w50, what is the advantage of this?
Old Apr 1, 2004 | 04:43 AM
Patman's Avatar
15w50 is too thick, go with 0w40 instead. The LS1 likes a thick 30 to thin 40wt oil.
Old Apr 1, 2004 | 10:43 AM
Glenn98ZM6's Avatar
realize that M1 is on the thin side compaired to the same viscosity of Dino oil. i also run 15w-50 M1 in my car. and i have for well over a year or so. my car is used for road racing and spends lots of time above 5K (like 20 minutes straight). i use this wieght to fight the thinning of the oil due to temp (was 300 degrees + before the oil cooler). just be smart and let the car idle for a minute before you drive off.
Old Apr 2, 2004 | 04:31 AM
Patman's Avatar
If you see high oil temps, it's best to do what Glenn did and get an oil cooler, instead of running the thicker 15w50.
Old Apr 2, 2004 | 09:40 AM
ssfiress's Avatar
its all about 10w 40 amsoil.
Old Apr 2, 2004 | 09:59 AM
blacktransam's Avatar
10w30 for break in then 10w40 redline for the rest of her life. remember adavanceautoparts stores now carry redline in stock.
