new timing chain with new cam?
Old Mar 4, 2003 | 10:35 PM
FrankSS's Avatar
Default new timing chain with new cam?
hey guys, i was wondering if you have to replace the timing chain on the motor when doing a cam swap? is it mandatory or just optional? TIA <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 4, 2003 | 10:39 PM
Texas Terminator's Avatar
Default Re: new timing chain with new cam?
spend the $88 on a double roller from scoggin/dickey while you are in there.
Old Mar 4, 2003 | 10:59 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
How many miles are on your stock chain? I only had 5K on mine when I did the cam so I saw no reason to replace it.
Old Mar 5, 2003 | 05:41 PM
2001CamaroGuy's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RPM WS6:
<strong> How many miles are on your stock chain? I only had 5K on mine when I did the cam so I saw no reason to replace it. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You will see a reason if you check the slack in the stock chain. I did my head/cam swap with about 25,000 miles and could advance/retard the cam at least 1 or 2 degrees just with the slack in the factory chain (checked this before I removed anything....). Get the double roller from sdpc2000.com. Its will last forever and you can advance/retard the cam with the keyways in the crank sprocket.
Chris
Old Mar 5, 2003 | 10:53 PM
ssdungeon's Avatar
Should I change at 24k on a TR227 and if so which one they have a few different ones
Thanks,
I need to know asap before the end of the month
Old Mar 5, 2003 | 10:54 PM
ssdungeon's Avatar
Thanks,
My car is a full bolt on 2000 SS
