best harmonic balancer?
Old Jul 22, 2012 | 12:01 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Very nice! ya got some time in that thing!
Old Jul 22, 2012 | 01:49 PM
sweet99ss's Avatar
So is stock pulley good for high rpm?
Old Jul 22, 2012 | 02:02 PM
JUSTINSWS6's Avatar
**** no! mine flew apart when it broke loose and hooked again rubber piece came out.
Old Jul 22, 2012 | 02:04 PM
Paul Bell's Avatar
"High RPM" as limited by the factory PCM RPM limit, yes, if the damper is in good condition. This means the rubber ring hasn't deteriorated .
Old Jul 22, 2012 | 03:23 PM
NVR_SPDS's Avatar
Isn't ati and slp the same one?
The SLP is just a reboxed Powerbond U/D pulley.
I always heard good things about slp pulley's.. I bough one a couple months back actually... Should I not install it?
Plenty of people run the crap out of these pulleys with no issue. Its when you start talking about higher RPM stuff, when they really arent a good idea. I have U/D pulleys on both of our WS.6s, daily driven, and slightly abused with no issues whatsoever. I will add that both are stock bottom ends, and dont see anything more than about 63-6400rpm.
Old Jul 22, 2012 | 03:46 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
That's a nice set up soundengineer. I'll be ordering mine w/o the allocated AC pulley here soon.
I like that motor plate set up you have. I wish I could find out more about it....
Old Jul 22, 2012 | 05:28 PM
soundengineer's Avatar
aeicnc.com
he's in the process of moving right now, so the shop will be closed down and a very limited amount of production will be done...
but he can probably still get the motor plate cut for you...its just gonna take a little bit longer than it normally would.
