Good N/A Boost Cam anyone?
Old Jul 25, 2012 | 01:39 PM
needtransam's Avatar
Default Good N/A Boost Cam anyone?
Im planning on a future turbo build so want to install a boost Cam until that day comes and was wondering a good boost cam that makes good numbers N/A??
Any input appreciated
Old Jul 25, 2012 | 01:42 PM
moeZ28's Avatar
G5xb...even for a blower cam it has a nice little lope to it and is not too big to drive around on.
Old Jul 25, 2012 | 01:48 PM
oh yeah needs to be streetable
Old Jul 25, 2012 | 10:53 PM
hotjohnnyls1's Avatar
i was running the speed inc sc4 specs are 234/240 on a 114lsa it worked great!
Old Jul 26, 2012 | 07:21 AM
Ethan[ws6]'s Avatar
Lol.. You are just going to have to pic one, N/A or boost, and stick to it. Make a compromise. If you want good numbers on boost, get a cam made for that. If you want good numbers N/A, get a cam made for that.. Can't have the best of both worlds lol
Old Jul 26, 2012 | 10:00 AM
SSpdDmon's Avatar
I'd be willing to bet that the 224/228 .581/.588 cam would suit you quite well. The only thing I'd check with someone on is what LSA you'll want. I'm assuming at least a 113 or 114 to keep out of negative overlap based on your future plans... That cam plus a good set of double springs should hold up quite well though.
Old Jul 26, 2012 | 10:07 AM
Mike Morris's Avatar
Post 01 LS6 cam or LPE GT2-3 work great with turbos and are decent n/a with no lope. 281LRHHR13 by Comp cams is a good max power turbo cam but its choppy. TU1 cam from Speed INC is another good one that is very dd friendly and easy to tune. VS speed has lots of turbo cams too with the VTC2 being the most popular for street cars. Contact Chris @ East Coast Supercharging as well he has a lot of experience with turbo LS1 cams.
Old Jul 26, 2012 | 10:14 AM
ss454327's Avatar
The 224R or 228R would work well in both NA and boosted applications. Honestly though I would get a cam designed for my turbo build and go with that. The NA loss (from a true NA cam...it will still make a lot more power than stock) from a boost cam will be worth it when you slap on the turbo.
Old Jul 26, 2012 | 04:20 PM
G Engines's Avatar
What are the rest of your car specs and engine combo your looking into ?
Old Jul 26, 2012 | 05:26 PM
6PntHo's Avatar
I'm going with the tu1 with my build.
Old Jul 26, 2012 | 05:28 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
We have a 224/228 .581/.588 114 LSA cam that seems to work well with boost and on motor. It has a broad powerband and a little chop at idle so a lot of people like it. The 228R on a 114 would be another good motor/boost cam. Most boost cams are pretty drivable once tuned because they are not very big.
Old Jul 26, 2012 | 05:48 PM
SSpdDmon's Avatar
Agreed.
Old Jul 26, 2012 | 09:09 PM
PREDATOR-Z's Avatar
Plan your turbo build on paper, type of turbo, size, etc and match a cam specifically for that setup. (If boosting is a concrete achievable project). That way you'll have the parts optimized for your goal. Different size turbos react differently to different cams.
As experienced turbo builder opinions, decide power range needed (not just I want XXX hp). What works for 1 setup might act differently in another.
Old Jul 27, 2012 | 01:40 AM
Blk98Vert's Avatar
The Brutespeed FI is greay in both apps
Old Jul 27, 2012 | 06:56 PM
Originally Posted by SSpdDmon
Agreed.
LOL, didn't see you had already said that. Thanks for the plug!
Old Jul 27, 2012 | 08:00 PM
got milk??'s Avatar
224r on a 115 LSA. Everyone has an opinion on what is "streetable". Some people will say that a MS4 size cam is a daily driver. I encourage you to find someone with a cam and ride along or drive it. You are the only person who can decide if it is daily material and the maintenance that comes with it is worth it. Good luck on your build and take in the advice some of the senior members here give because its tried and true!
Old Jul 28, 2012 | 12:31 PM
Fbodyjunkie06's Avatar
If you would like to go over specs and a cam for your build call me at the shop on Monday and I can give you some ideas for what to use.
Our cam packages start at 680-700 dollars.
Old Aug 6, 2012 | 06:12 AM
10secondZ's Avatar
Just got the 224/228 .581/.588 115 LSA for my turbo set up from texas speed. I know that cam works very well and is very street friendly N/A and boosted
Old Aug 6, 2012 | 07:45 AM
Something like 226/231 .605"/.598" 113+2 or 114+3 would work well. LXL/HUC lobes. I think this combo of lobes would make an awesome boost cam and still make great power N/A. Nice soft lobes with good area is what you want with a boost cam, especially on the exhaust side which the HUC lobes do very well while still keeping a fair amount of intensity on the intake with the LXL lobe.
