Need help dropping oil pan on 3rd gen
My son's car [1987 Z28 305 A4] oil pump crapped out. We did everything that the Chilton Book said. We removed the motor mount bolts, tranny bolt, oil pan is down, but just won't come out with the motor jacked up all the way. Am I missing something here or do we have to pull the engine to get this thing out?
Any help would be appreciated. Thanks,
Tim
I had mechanic buddy stop down the other day and we tried that twice. It seems that we are this close to getting it down, but it just won't give.
We are jacking it up on the harmonic balancer, is that a good spot? This is going on day 5 playing with this damn thing. My T/A is getting pissed sitting out in the rain and I want my garage back.
This is my next plan of action
Thanks
Make sure the transmission mount isn't in a bind, should be completely unbolted from the crossmember so it can move w/ the engine as you raise it.
Might need to remove the distributor to get extra firewall clearance, and that last little 1/2" to get the pan out. Good luck!
] Next he is going to pull the bell housing and yank the engine. Gotta believe this should work. Looks like I will be busy tomorrow night.
Just watching...Thanks for all the suggestions.
