bad knocking sound?? lifter??
Old Apr 4, 2004 | 03:54 AM
98sspullin'em's Avatar
Default bad knocking sound?? lifter??
i have no idea what a lifter sounds like when it is going bad... i know what a piston hitting the head is, i just got done putting my new motor in because of that..
i made some passes at the track and the next day i let it idle with the hood up and every now and then i heard a cling sound and i drove it about 10 min real light to my house and my buddys came over and i let them hear it and right when i started it, it was horrible!!! loud as hell, they were yellin shut it off shut it off...
could that be more than 1 lifter going bad?? when i changed my motor, i did not get new lifters... i only have about 800 miles on the new motor and 94k all together on the lifters...
could it be that or maybe the flywheel? or whatever you call them in A4's??
any helkp would be great... just check the rockers then the pushrods first??
Old Apr 4, 2004 | 03:55 AM
o and i noticed my oil pressure has been lower than normal.... it is around 25-30 on idle and at 40psi going 80 on the highway!!!??????????
Old Apr 4, 2004 | 07:06 AM
98_1LE's Avatar
I hate to say it, but I would think a rod bearing is more likely the culprit. Who rebuilt the motor?
Old Apr 4, 2004 | 01:05 PM
i hope not, i just put that new motor in too ... a guy that worked at mti but quit and opened his own buisniness....
how could i tell if it was a lifter.. what is diff about them when they are dropped or collapsed or whatever
