comp trunnions and summit trunnions the same?
Old Jul 30, 2012 | 11:32 PM
3rdCoastPowerSports's Avatar
Default comp trunnions and summit trunnions the same?
looking at upgrading stock rockers to trunnions. I notice that summit sells a comp kit that includes bolts. summit also sells a summit brand trunnions kit that i don't think comes with bolts. Any one used the comp or the summit kit would be nice to hear from you. Also do you have to get new bolts or can you reuse your stock rocker arm bolts?
Old Jul 31, 2012 | 12:22 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Due recess in the shaft to locate the bolt on Comp's kit, you need to use the supplied bolt. I cant say anything on Summit's as I havent seen any, yet even knew they had their own at this point.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Jul 31, 2012 | 08:54 PM
brnagn's Avatar
I just saw the Summit brand earlier tonight. They are $35 less than the Comp Cams kit. I'm curious about the difference as well.
Old Aug 1, 2012 | 12:33 PM
sshook2000's Avatar
Just got done doing mine. Looking at the summit kit it does not come with the washers for install which was a must when putting the trunnions in the rockers. I had look at both and went with the comp's.
Old Aug 1, 2012 | 02:58 PM
RezinTexas's Avatar
The washers with the comp set are a big plus.
