Need help identifing my cam
Old Aug 3, 2012 | 02:15 AM
Blk98Vert's Avatar
Default Need help identifing my cam
This is a major longshot but hopefully someone has an answer. My GTO has a 347 built by CBM. My problem is that the build was done back in 2009. I called CBM and they do not have the specs on file because of its age, they have gone with a new grind for their motors. The prior owner told me it is around a 224, but honestly it sounds and feels bigger to me. The only clue I have is on the build sheet i have it says "CAM 2833". If anyone can help me out I'd appreciate it, I would simply like to know so I can tell people that ask me about it more than I have no idea.
Old Aug 3, 2012 | 10:32 PM
usmcpi's Avatar
Well the most accurate way would be to pull the cam. It should have the serial number, lobe numbers, etc ground into it and you can call whatever company (comp, cam motion, lunati, etc) and ask.
Old Aug 4, 2012 | 03:17 PM
Blk98Vert's Avatar
Obviously, but I have no reason to pull it, there is nothing wrong and I don't absolutely need to know what is in there
Old Aug 14, 2012 | 03:15 PM
v8fd3s's Avatar
OT but is this justins gto?
