Main and rod bearing clearance
Old Aug 10, 2012 | 09:59 PM
cory32690's Avatar
Default Main and rod bearing clearance
Ls1 rebuild had crank turned .010 on main and rods using scat I beams 6.125 wiseco 3.905 pistons using clevite p series on main and rods motors gonna be in a daily drive h/c/I car with maybe a shot down the rod no more than 150
What is a good clearance for the bearings that will be fine for na and small shot
Old Aug 11, 2012 | 07:14 AM
G Engines's Avatar
.0020 to .0024 on mains and rods
Old Aug 11, 2012 | 09:24 AM
cory32690's Avatar
Thanks anyone else
Old Aug 11, 2012 | 12:46 PM
Gray86hatch's Avatar
No more that .002 on the mains with alum block. Rods .0025 is fine.
Tim
Old Aug 12, 2012 | 12:06 PM
cory32690's Avatar
Did the mains last night .002
Waiting on piston ring compressor to come in and will do rods next
Thanks for the replys
Old Aug 12, 2012 | 01:43 PM
3rdCoastPowerSports's Avatar
your mains are good at .002".
this is a good read for some Rod bearing clearance info:
https://ls1tech.com/forums/generatio...0-hp-shot.html
