New Lifter Install
Old Aug 14, 2012 | 06:43 AM
beach cruiser's Avatar
Default New Lifter Install
I decided to go ahead and upgrade to LS7 lifters while I have the heads off and the cam is still new. I ordered the LS2 trays as well. I plan to drill the bottom of the trays for better oil drainback (road race car), Question is, is there any pre oiling proceedure for the lifters before I stick them in the motor? Do I let them soak in a pan of oil for a while before hand or just install them Dry? I do plan on poly lubing the rollers prior.
Old Aug 14, 2012 | 06:53 AM
jblankenship's Avatar
Soaked mine in new oil for about a week in a Baggie. Start up was just about perfectly silent as far as top end noise. I Did spin the motor over first with plugs and injectors unhooked.
Old Aug 14, 2012 | 09:34 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Soaking them in oil should be sufficient.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 14, 2012 | 12:52 PM
therabidweasel's Avatar
You can cycle heat and cool in oil a time or two which will help them expel air and draw in oil. Overkill, but why not?
