Foreign object in block during cam swap
Here is what caught my eye when I pulled the pump off:
Here is one shot of the piece after I pulled it out:
Here is a different angle of the piece of metal:
On another note this is what I was greeted with when pulling the coolant hose from the TB. The last person must have been running just water through the system.
http://www.thirdgen.org/techboard/lt...-overheat.html
it's very weird, but I'll be flushing the engine water jacketing and radiator to make sure that was the only piece. I dont need more metal wiping out my new pump when i install it. Let me know if you get to the bottom of your search. Today i torched my old pump to remove the impeller and it looks fine, so does the internals of the water pump cast housing....so i have NO CLUE where my piece of metal came from....weird.
The only thing it somewhat resembles is a cast trunion nut
I'll check on that before I put the water pump back on. Maybe I'll go ahead and add a 160* to it while I'm at it.
