Which roller rocker to go with?
I don't believe Jake understood your question, so I will answer it. The rocker with the trunion upgrade will still side load and wear the bronze guides. The trunion has been changed, but no roller tip was added to the rocker. An aftermarket roller rocker should be used with bronze guides to avoid side loading. I prefer the Yella Terra rockers, they have the largest trunion and smallest nose wheel in the industry.
Sorry, I did get a little side-tracked, but you have pretty much covered it!
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
