Which flywheel?
Old Aug 21, 2012 | 04:39 PM
Fuego's Avatar
Default Which flywheel?
Using a stock 2000 LS1 for my sandrail build and still need to get a flywheel. I have already purchased the clutch and pressure plate, but not sure which flywheel to go with. Would the billet steel be a better choice under loads like sand vs. the billet aluminum? Or would a stock camaro flywheel do the job?
I'm sure im leaving out some info?
Old Aug 21, 2012 | 04:50 PM
Fuego's Avatar
Or maybe just school me about each! Thanks...
Old Aug 21, 2012 | 09:24 PM
wildcamaro's Avatar
Personally I would just run a factory unit just bc the quality of the material is good, unless you are either 1. Making crazy power or 2. Driving crazy lol....if you do buy an aluminum then make sure you have a rev limiter lol
Old Aug 22, 2012 | 04:17 PM
Fuego's Avatar
#1 not the case. #2 very possible the case. In the dunes there a lot of opportunities to get the front end in the air off of roller hills and hammering down up steep hills. I imagine the weight of the flywheel determines how fast the motor spools up?
Old Aug 23, 2012 | 10:06 AM
wildcamaro's Avatar
Right...aluminum will spin up much faster, but billet aluminum flywheels are damn expensive...I prefer steel just bc of its longevity...billet steel would be top dog...
Since the aluminum is light it will spin fast, BUT the steel flywheel will provide more inertia to get you going up those steep sand hills...
Road racers usually use aluminum for quick revs and drag racers use steel to provide a good launch off the line...
Old Aug 23, 2012 | 04:32 PM
Hotrnhell's Avatar
I got what need. Pm me
